2nd Gen Non-Engine/Transmission A/C line leaking
The A/C line that runs from the radiator like piece at the front of the truck to the compressor is leaking. The line contains the pressure sensor by the oil filter.
Where can I get a new line? Is the dealer my only option?
Thanks,
Aaron
I checked when I got home tonight and the line I am referring to is the one with the connection point for charging/testing that is down low, near the compressor. It also has a red cap.
I'am asking if anyone has experience with replacing this line and if it is significantly cheaper thru Napa, Advance, etc than the dealer.
If you are able to see the leak and get to it easily, use JB Weld and let it sit overnight... Then charge it up the next day... Works!! Fixed my leak on it...
