As an old HVAC Tech I have to say to you all, "use caution when working with refrigerant systems", just adding some "because" may possibly be the worst thing to do. It's a common misconception that the system needs a periodic "tune up" and requires the addition of refrigerant to keep it working & happy. Or, my A/C isn't blowing as cold as it was last year, it must need some refrigerant. "A tight/properly charged system is a happy system". I know this sounds corny but, it's true.
If you have to "add refrigerant" it's for a reason - there's a leak somewhere. It's best to locate the leak and repair it, then have the system properly evacuated and recharged. The best method I've found to "properly" recharge the system is adding the "Factory" charge of XXX amount pounds & ounces. After a repair, in which the system has been "opened up" and subjected to the atmosphere & moisture contained within, requires the system to be evacuated of air/moisture. Of course there's special tools/equipment that most of us don't have that have to be used. This "method" of charging ensures that what engineers have calculated as the "ideal" charge amount is returned to the system.
I purchased my truck in mid 01 w/75k miles, it now has 124k, I've never had to "add" refrigerant. I consider myself lucky that my system is "tight and happy" especially since I know the truck was in a front end wreck and repaired prior to ever my seeing it. I guess someone did the correct repairs so I wouldn't have to.
My $0. 02
