My a/c stopped blowing cold air! The compressor cycles so I figured it was low on freon. I took the truck to A/C shop and had them check out the pressures. They said the pressures are fine but I should try replacing the orifice and drier. They also told me that moisture builds up in the lines and it may look like the pressures are correct. It seems to me they didnt know what was wrong and just wanted to start replacing things. The temp blows about 78 F with ac on max.
I pulled the low pressure switch and jumpered the wires to keep the clutch engaged and the air was blowing colder. (dont have temp gauge yet) I dont want to replace some parts and it not fix the problem. The truck sits all week and I only drive it on the weekend. I figure I should try this site before I let anyone touch it. If anyone knows of a good A/C repair man around Austin, TX let me know because it is HOT! Thanks
