A/C only blows out the defrost and floor vents
Mechanical temperature gauges ports?
Spare tire winch tube
Check the hose on your Vacuum pump and follow the line to the firewall where it enters the cab, defrost is the default setting with out vacuum.
The vacuum line was severed, so I spliced with vacuum line. However no change to ac blowing from defrost and floor vents.
