It's pretty HOT here in Nashville TN, and I could use some help diagnosing my A/C problem. I understand that the system only cools the interior about 25 - 30 degrees from the outside temperature. Last week it was not cooling at all so I checked the low side pressure with one of those refill cans sold at the auto parts store, and it was about 25 psi. So following the directions carefully I added some to bring up the number. All was good until today 104 degrees outside and it felt like 110 in the truck. I checked the pressure and it was about 42 / 43 psi. It seems as if when I accelerate using more than a quarter of throttle it shuts off the compressor. No matter how quickly I get up to the posted speed limit the compressor won't blow cool/cold air for 3 or 4 minutes. Just enough time to feel miserable in the non AC cab.
I know the quicky fix cans of coolant is not the proper way to repair the AC, but what is causing this on and off again problem.
1. If I let out some freon will that stop the on and off issue ?
2. The radiator/inter cooler/condenser fins are clean. ( cleaned them 3 weeks ago and rinsed them out again tonight )
3. I do have that pesky oil leak between the power steering pump and vacuum pump problem ( didn't know it that would be related somehow )
4. I have 220,000 miles and all of the AC system is factory original.
5. I am on a tight budget as I own / operate a one man lawn care business and we are drying up fast around Middle Tenneessee so I won't have much money to throw at it until fall.
Thanks in advance
Dave D.
I can't think of anything else to provide you more info than that.
Thanks in advance
Dave D.
