Looks good did your coat your pistons???? What injectors are you running???
didnt coat the pistons this time, i will next time, i will be running industrial injection 8 hole 63 lph injectors being pushed by a stage 2 cp-3 on the bottom and a stage 3 duramax pump on top, i kinda want to try the cp3. 4 but i havent seen anyone make power with it...![]()
, GOING TO BREAK IT IN WITH STOCK CAM, SPRINGS, AND A SINGLE CP-3 WITH BLOW OFFS AT 50 PSI, THEN WILL ADD THE HELIX CAM,SPORTSMAN SPRINGS,AND SECOND CP-3 THEN SET THE BLOW OFFS AT 75PSI AND TURN THE FASS 200 DOWN TO 20 PSI AND SEE IF IT BLOWS UP AGAIN HAHA:-lafCool hope all goes well... Keep the pics comming. . Did you go with a cam and springs?
