Maybe some of you have thought of this but I did not find it posted in anything recent.
Note: I have not made these voltage measurements yet, maybe one of you have.
The lift pump, basically a standard 12V inline fuel pump. 90% of the electronics in the world are designed to operate at a certain voltage within say +/- 10%. That means the lift pump is designed to operate at 10. 8-13. 2volts.
The manual states
"Pressure Test: Because the transfer pump is operating
at two different pressure cycles (engine running
and engine cranking), two different pressure tests
will be performed. "
The minimum running pressure is 10psi, the minimum cranking pressure is 5-7 psi. The pump is controlled by the ECM, to achieve 10 psi we can assume the ECM is providing 12v, to achieve 5 psi I assume the ECM is only providing 6v, which would be out of "specs" for the pump design. Operating any electrically device under or over voltage specs will lead to early failure.
Possible solution: A 6 to 12 volt relay between ECM and pump that when closed supplies battery voltage to pump.
Your Thoughts?????
The manual states
Your Thoughts?????
