why do a lot of people use the holley blue fuel pump. when i read the specs it makes me believe that its not too much better then the stock. I am not looking to put one on my truck i was just reading about them. here are the specks i found on holleys site
New lower housing casting for enhanced fuel flow
Motor draws only 3 amps current
7 1/2 amp fuse recommended
Improved design for street/strip applications
Flows 110 GPH (free flow)
Flows 88 GPH at 9 PSI
Maximum pressure is 14 PSI
Provides constant fuel flow with no pulsation
Has externally accessible pressure relief valve (max 14 PSI)
Rotor/Vane pump design is more tolerant of contaminated fuels
Can be serviced from either pump end or brush cap end
NOT compatible with alcohol or methanol fuels
Not designed or recommended for use with fuel injection systems
Holley Performance Products 110 GPH "Blue" Electric Pump Without Regulator*12-812-1
just asking a question if you have one maybe tell why you chose that if you do not have one and bought something differnt share why also. i chose the fass 150 because i liked the filter setup and the volume and pressure it can flow. i also knew that i was going to be bombing my truck when i bought it.
