A T-Case Buzz soloution from Kentucky
Headlight Problems (more) Help
"Death Wobble" cause
Yesterday Philip and I made a 770 mile round trip from northern Indiana to Nashville, TN to pick up two hay rakes. We took my 1993 W-350. After 4 hours of listening to the transfer case lever buzz, we came up with a solution. We were in Kentucky when this solution was discovered, so it is OK for a couple of Yankees to do this. :D
Jeremy
BTW, 18 hours in a 1st gen at 70 mph will make you do some strange things.
On a bit more serious note, I thought I would share some numbers. I was pulling a 33' flatbed gooseneck that weighs in at 4500 lb empty. Loaded it weighed in at 7800 lbs. Over the 770 miles I got an average of 11. 85 mgp. Pretty good for an old truck with 286K on the clock. I am running a PDR HX-35/16 with a custom ground fuel pin. Fuel screw is in some. Max boost is 28 lbs. The turbo and fuel pin made a heck of an improvement on towing. Well worth the effort. :D
As for the tune on the bungee, it was "Dueling Banjos". Patent is pending, but I think I will get lauged out of the patent office. Duct tape did help, but not enough.
As for parts lost on the trip, lost the left rear brake due to a hold down clip breaking and letting the rear shoe come loose. The right rear axle seal started leaking again. :mad: Plus the cheesy dual exhaust setup is loosing the left pipe due to all of the pounding down the interstate. Time for a 4" exhaust. Other than that it was a fun trip.
Jeremy
I used one of those "Kentucky" fixes a few years back, I found that it just takes a little tension at the bottom of the leaver to stop the rattle:D
Maybe we need to elevate bungee usage to the level of duct tape usage. ;)
Bungie technology. Ya gotta love it.
Who said necessity was the mother of invention? Bah humbug.
It was laziness and aggravation!!!!
Bubble gum was in the glovebox for backup right?
