I've noticed that at times the A518 doesn't want to shift up when I think it should, when its cold. If I get in after its been sitting for a day or two... and take off... it seems to "hang" in 1st a little too long for my liking. The RPM's will go up to where I think it should shift then I'll hold it there. A few seconds there it will finally shift. Once warmed up... it will shift normally.
Any adjustments for this or just the nature of the cold fluid and "unfilled" TC?
Also... I was playing around with removing the Valve Body and accidentally turned the line pressure screw CCW a turn or two thinking I could remove the VB easier by removing more parts. That was a mistake when I saw there was a spring behind the screw. I instantly realized it was an adjustment screw and not a bracket screw. So I turned it back 1 turn not realizing exactly how far I had gone. No more than two turns anyhow. (Dumb I know... but it was HOT in the garage, shop light was in my face, and I had never seen the inside of the 518 before).
Will one turn extra on the line pressure screw CCW hurt? DTT site says 1 turn CCW is 5psi more pressure. Is there a way to take it to baseline without gauges for pressure? IE: fully turn in then back out 7 full turns? Or am I way out in left field?
Eitherway... I'm pretty close to what it was anyhow.
