TDR Folks,
Q. What does your AAM Center Support Bearing (CSB) rubber suspension/bumpers look like?
2005 5.9L NV5600 QCSB over 200K on the clock.
I'm investigating a seat/rear body vibration that has possibly been a long time lurking problem but made it to the radar screen and is getting some attention. This AAM driveline has only been R&R for clutch work, all parts are as built. It will come out for a detailed U-joint insp but nothing obvious in the on vehicle evaluation but it could prove me wrong later. TBD.
Take at look at the two pics, one I'm showing the gap that can be seen at the bottom of the CSB rubber bumper to the bearing assy just by pushing up with both hands. It's right at 1/4". It appears that this CSB suspends the bearing from each corner of the frame and has travel bump stops at top, bottom and the sides. ?
The second pic shows my home shop diagnostic attempt. The red strips are rubber and are 1/8" thick and it didn't take much effort to slip them in at sides, top or bottom. This pic shows both at the bottom current test is one ea at top and bottom. Next up test drive for a bit to evaluate and make decision as to next step, parts etc. The jack is only supporting the shaft in the UP position, not much force at all.
I did find an informative AAM bill of materials for my driveline https://www.demandaam.com/technical...ials/ram-2-piece-driveshaft-bill-of-materials use your driveshaft part numbers and check for AAM assy and components that it uses.
I haven't had enough seat time on various roads to determine outcome to knock down or at least "touch" a possible source etc.
Gary
Gary
