Abbreviations, Acronyms and TDR lingo
is 2 gallons> antifreeze enough?
Just bought 2007 2500
As a first time diesel owner, I have found my TDR subscription to be the best place for my money so far. However, as a newby, it can be hard to read some of the threads posted by the old timers as they are full of abbreviations and acronyms that aren't heard every day (other than here).
So feel free to post more commonly seen abbreviations and acronyms.
TDR: Turbo Diesel Register. You're lookin at it!! :D
CTD: Cummins Turbo Diesel; what you drive; commonly refered to by neighbors as "That big, loud, thing of your's!!!"
BOMB: Better Off Modified Baby; anything that makes your CTD better (it is possible)
BHAF: Big Honkin' Air Filter check this thread BHAF picture
FP: Fuel Pressure
EGT: Exhaust Gas Temperature
For the non-computer types:
BTW: By The Way
LOL: Laughing Out Loud :D
ROFLMAO: Rolling On Floor Laughing My Anal cavity Off :-laf :-laf
ETH= HO Cummins engine order code
ETC= regular cummins as in 5spd or auto
DEE= NV5600 6Spd transmission
DTT= Diesel Transmission Technology, a company that makes transmission products
VB= valve body in an auto transmission
TC= torque converter
DD= diesel dynamics
or
DD3= a DD injector stage three
I am just thinking of sigs that would throw you off if you didn't know the abbreviations.
Ted
Piers = God
Here are some from DodgeRam.org
2WD Two Wheel Drive
4WD Four Wheel Drive
ABS Anti-lock Brake System: Modulates braking pressure to control wheel lockup
ACM Airbag Controller Module: monitors sensors and deploys airbag(s) in the event of an accident
AFC Air Fuel Control: used on 94 - 98 diesels to control fuel rate at low boost
APPS Accelerator Pedal Position Sensor: used on ISB diesel for electronic throttle control
ASD Auto Shut Down: relay control system used to shut down engine
BDC Bottom dead center - the lowest position of a piston in the cylinder occurs when the crank pin is at bottom dead center
BE model designation for the Quad Cab Ram pickup
BFSC Brake Specific Fuel Consumption - pounds of diesel fuel consumed to produce 1 HP for 1 hour
BHAF Big Honkin' Air Filter - oversized filter used by the diesel gang
BR model designation for standard cab Ram pickup (and maybe the CC Pickup) more below
CAB Controller Anti-lock Brake:
CARB California Air Rescouces Board: environmental regulatory agency in CA
CCD Chrysler Collision Detection: data bus system used by the airbag and the anti-lock brake systems
CHMSL Center High Mounted Stop Light: 3rd brake light at top of truck cab
CKP Crank Position Sensor: detects position and speed of engine crankshaft
CMP Camshaft position sensor: detects position of camshaft
CPL Control Part List: listing of engine parts and timing specifications for a Cummins engine (Ram CPL numbers)
CTD Cummins turbo diesel - used by many on mail lists and message boards
CTM Central Timer Module: controls RKE, chime, courtesy lamps, Speed sensitive Intermittent wipers, enhanced accident response, VTSS
DAB Driver Air Bag module: airbag and firing system mounted in the steering wheel center
DC DC or D/C = DaimlerChrysler - used on mail lists and message boards
DD1 DD1, DD2, DD3 = Diesel Dynamics Stage 1 (2 or 3) injectors
DEE Order code for the NV5600 6 speed manual transmission
DLC Data Link Connector: used to interface diagnostic equipment with vehicle electronics
DRB scan tool used to obtain diagnostic trouble codes (DTC) from controller modules
DRB III new generation scan tool used to obtain diagnostic trouble codes (DTC)
DTC Diagnostic Trouble Code: Fault code set by control module when sensor data is not as expected
DTT Diesel Transmission Technologies - aftermarket auto trans upgrade specialist
EBC 2 RWAL brake system
EBC 325 four wheel anti-lock brake system
ECM Engine Control Module: microprocessor based module that controls various engine functions
ECT Engine Coolant Temperature Sensor
EEPROM Electrically Erasable Programmable Read Only Memory: controller reprogrammable memory
EGR Exhaust Gas Recirculation: used to reduce combustion temperature and pressure to control Oxides of Nitrogen
emissions
EGT Exhaust Gas Temperature: Important measurement for hard working diesel engines
EMCC Electronically Modulated Converter Clutch: used for torque converter lockup control in the automatic transmission
ETC Order code for diesel engine
ETH 2001 Order code for the High Output diesel engine
ETH/DEE Slang for the 2001 HO diesel with the NV5600 six speed
EVA Electronic Vibration Analyzer - used to diagnose chassis, engine, and drivetrain vibrations
EVR Electronic Voltage Regulator: circuitry in the PCM which controls battery charging and alternator functions
FPCM Fuel injection Pump Control Module: controls injection pump on 98+ diesel engines
GAWR Gross Axle Weight Rating: maximum safe load capacity of an axle measured at the ground.
GCW Gross Combined Weight: total weight of equipped truck, payload, trailer, water, and equipment.
GCWR Gross Combined Weight Rating: maximum allowable GCW
GVW Gross Vehicle Weight: total curb weight of the truck and payload.
GVWR Gross Vehicle Weight Rating: maximum allowable GVW
HCU Hydraulic Control Unit: modulates the brake pressure for ABS
HX35 Holset turbocharger used for most 94+ diesel Rams.
HX40 Holset turbocharger intended for C engines, but used by
some performance enthusiasts on the Ram's B engine
HY35 Holset turbocharger used on 2000+ diesel Rams with the automatic transmission
IAT Intake Air Temperature Sensor
IAC Idle Air Control valve: used for emissions control on gasoline engines
IP Instrument Panel
ISB Interact System B: Cummins designation for the 24 Valve "B" series diesel introduced to the 1998 Ram
JTEC Jeep, Truck Engine Control: Combined engine and transmission control module
K&N Aftermarket filter and intake system manufacturer
KDP Killer dowel pin inside the timing gear case on 94-98 12 valve diesels. If this pin falls out of its blind hole, the repair is expensive. The two preventative repairs are the Washer Tab and Drill Jig/Bolt
LDP Leak Detection Pump: used in the 4 wheel ABS valve assembly
LED Light Emitting Diode: semiconductor lamp used for displays and warning lamps
LSD limited slip differential
LWB long wheelbase (or LB, for long box or long bed)
MAP Maximum Absolute Pressure sensor: used for emission control
MDS(2) Mopar Diagnostic System: diagnostic computer system for service departments
MIC Mechanical Instrument Cluster: Instrument cluster controller and display system
MIL Malfunction Indicator Light: used by engine control system to indicate a problem to the driver
MTV Manifold Tuning Valve: used to vary the manifold runners for engine performance and emission control
O2S Oxygen Sensor: measures oxygen content of exhaust stream. Used to modify air to fuel ratio for emission control
OBD On Board Diagnostics: Ram engine and powertrain self diagnostic system
OBD II On Board Diagnostics II: enhanced diagnostic system to meet 1997 EPA requirements
P7100 Fuel injection pump used with 1994 - 1998 Ram 12 valve diesel engines
PAB Passenger Air Bag module: airbag and firing mechanism on the passenger side
PADS Passenger Airbag Disarm Switch: Override switch to disable
PAB when children are riding in front seat
PCI Programmable Communications Interface
PCM Powertrain Control Module: microprocessor based module that controls engine and drivetrain functions
PCV Positive Crankcase Ventilation: vacuum system used to control crankcase (blowby) emissions
PDC Power Distribution Center: Fuse and relay power distribution center located under the hood.
PEP Peripheral Expansion Port
psi Pounds per Square Inch: pressure measurement
RAM Random Access Memory: read and write memory used by controllers for data storage
RKE Remote Keyless Entry: remote operated door lock system
RPM Revolutions Per Minute: the speed of a turning shaft or rotor
ROM Read Only Memory: controller "hard" memory that is permanently written - EEPROM may be reprogrammed with appropriate diagnostic tools
RWAL Rear Wheel Anti Lock brakes:
SBEC Single Board Engine Controller
SCI Serial Communications Interface: Used by the PCM for diagnostics and for communication with other controller modules
SCTM Seatbelt Timer Control Module: inertia latching seatbelt controller built into Quad Cab Models
SKIM Sentry Key Imobilizer Module: disables engine start until Secret Key is entered using DRB scan tool !!! Required when a new PCM is installed in a vehicle
SWB (or SB, for short box or short bed)
TCC Torque Converter Clutch
TCM Transmission Control Module: May not be used on Ram trucks
TDC Top Dead Center: the highest position of a piston in the cylinder occurs when the crank pin is at top dead center
TDR Turbo Diesel Register - club for Ram diesel owners - with a website, magazine, and rallys
TPS Throttle Position Sensor
TRS Transmission Range Sensor
TSB Technical Service Bulletin: repair and technical information bulletins to assist service departments
TST Diesel engine power enhancement company run by Mark Chapple
VB Valve body - auto trans
VE Bosch Distributor type injection pump used on 89-93 Ram diesel engines
VP44 Bosch electronic fuel injection pump used on 1998+ Ram diesel engines
VIN Vehicle Identification Number: unique serial number assigned to each vehicle
VSS Vehicle Speed Sensor/Signal
VTSS Vehicle Theft Security System: anti theft system with engine disable, alarm, and door lock features
WIF Water In Fuel sensor: detection system for water in fuel filter on 1994+ diesel engines
WOT Wide Open Throttle: maximum throttle position
and here are some that illflem posted a while back... .
AAMOF as a matter of fact
BBFN bye bye for now
BFN bye for now
BTW by the way
BYKT but you knew that
CMIIW correct me if I'm wrong
EOL end of lecture
FAQ frequently asked question(s)
FITB fill in the blank
FWIW for what it's worth
FYI for your information
HTH hope this helps
IAC in any case
IAE in any event
IMCO in my considered opinion
IMHO in my humble opinion
IMNSHO in my not so humble opinion
IMO in my opinion
IOW in other words
LOL lots of luck or laughing out loud
MGB may God bless
MHOTY my hat's off to you
NRN no reply necessary
OIC oh, I see
OTOH on the other hand
RCH red c*** hair(unit of measure)
ROF rolling on the floor
ROFL rolling on the floor laughing
ROTFL rolling on the floor laughing
RSN real soon now
SITD still in the dark
TIA thanks in advance
TIC tongue in cheek
TTYL talk to you later
TYVM thank you very much
WYSIWYG what you see is what you get
YKYBNTLWYKT you know you've been on the net too long when you know all these
Have fun,
Andrew
Andrew, Looks like you were busy typing up that list, good job. The moderators should bump your post count up at least another 20 for that one.
Dean
Unless I missed 'em:
TTT - To The Top (had me buffaloed)
YMMV - Your Mileage May Vary
WTF - Where's That Fred?... Went To Florida... (or make your own)
TxDieselKid, is this CTC a plot? (Commie Torque Converter)
You left out ATS from your list of acronyms!
(ATS is Automatic Transmission Specialists, from Denver, who make the TripleLok TC)
HVAC
I always thought HVAC meant Heating, Ventilation & Air Conditioning. But after reading thousands of posts, I think it means Highly Venerated Awesome Cummins, (or something to that effect) otherwise known as the person who builds, maintains and drives a high powered personal red rocket. Correct me if I’m wrong. Hey, does HCAC have a pilot’s license to fly that thing?
BTW, I’m glad to finally know what LOL means. Always thought it meant Lots Of Laughs, but Laughing Out Loud makes way more sense.
Dean
Just now saw this, don't be jealous Dean. ;) Havn't you noticed how quiet I am nowadays? :p
Andrew
