Abbreviations, Acronyms and TDR lingo
is 2 gallons> antifreeze enough?
Just bought 2007 2500
Another forgotten one
Don't forget BOOB, we are all BOOB men/women
Brotherhood
Of
Oil
Burners
ALL HAIL THE BOOBS!!!!!!!!
Jake
VE is the rotary injection pump used from 89-93
VP44 is the electronic injection pump used from 98. 5-02
P7100 is the inline mechanical injection pump used 94-98. 4
CP3 is the high pressure pump used in the common rail engines of 03-current.
GSK is a govenor spring kit.
Did I get em all ;)
-Scott
When you turn the key on the lift pump will run for 5 seconds then shut off. If you want it to run more just bump the starter (begin to crank then stop before the engine has time to start) and the lift pump will run for another short period of time.
-Scott
Did any one post this one yet.
CTI = Cycle The Ignition.
To get your codes, CTI four to five times.
Excellent Thread though.
Electronic Discharge Machining: A Proccess where CNC aimed "arcs" (I guess) are used to make the perfectly placed, perfectly round, burrless, dead on angle holes in the BETTER "EDM" Injectors. Hard to drill perfect holes that are less than 10 thousandths in a hardened tip made to withstand great heat.
