Hello all,
I am a second time owner of the new 24v engine. My 1st was a 99 3500 5 speed that I had absolutley no problems with. I decided to trade up to a 2001 3500 recently when the dealer made me a deal i couldnt refuse(not that i was looking).
I did not modify the 99 at all, but the 01 is goin to be a different story. I have been looking at different mods since i had my 99 & I think I have found the fuel managment I might go with. Blue Chip Diesel makes a fuel managment that allows the user ultimate control in 1% incriments. Now I know that may b a tad overkill, but the 1% will allow absolute tuneability around where you finally like the set it. ie. clutch starting to slip... . back off 1% till it stops... .
My question is:
Has anyone used this product? Is it all it claims to be? Is it really overkill? I know it is a bit $$ @ $1300, but it gives you maximum control with one unit. ie. egt, boost, fuel pump management w/ display of each. The other units that are available out there only have up to 5 different preset settings that may be way out of your range with the stock clutch.
Any feedback would be greatly appreciated before i spend my hard earned loot.
Thanks
Cole
p. s. this is only the fuel management portion of the mods in question. I am stil planning on modify the clutch, exhaust, injectors, & turbo housing in due time.
My question is:
Thanks
Cole
