2nd Gen Non-Engine/Transmission ABS and Brake light and Spedo
Engine/Transmission (1994 - 1998) 95 Where to go from here??
Both brake light and ABS lights stay on and the speedometer is intermintent.
From what I read I think its the speed sensor, VSS in the rear end. I pulled the plug on it and checked with an ohm meter, looking for about 1800 ohms and it was zero. Where will I find the best price for one? And if anybody has a part# that would be appreciated.
Thanks in advance, Bill
There are several recalls about the abs and brake light being illuminated due to a wiring malfunction in the harness. It doesnt say anything about the speedo though.
Wires
Follow the wires leading away from the rear end speed sensor as well. I found mine had a chafe in them along the frame rail after I replaced the sensor (for the second time). Fixed the wiring, and put some split loom around it, been doing great since.
Craig
More than checking the electrical of the sensor, you may need to pull it and clean off any metal chaff that has gotten glommed onto it - this has been known to cause strange intermittent action. And yes, the vss does send a feed to all the devices you describe as being squirrelly.
