Chief USA
PCM/ECM test shows P0500 & P1693. I have a rear axle abs sensor replacement on order. Spoke with a friend who had this problem on his 2nd Gen truck but he did not remember the issues with the blower fan and power windows?
On initial start up, if I recycle the ignition switch and let it self test until it finally passes, everything works great until the abs, brake, & airbag light come on again on the next start up.
I will be troubleshooting some connections and looking at the abs and some other fuses as well.
I tried doing a forum search and found only a single instance of this here:
https://www.turbodieselregister.com...trical-problem-need-help.242159/#post-2342230
The thread was locked and the op has not been on the website since 2018. Has anyone else encountered this problem? If so, what did find to be the problem & fix. Thanks in advance & Merry Christmas to all!
