Archived Abs Brake Help
Archived Running with an EGT of 400, then nothing
Archived lost power steering & power brakes
My abs pump motor keeps running after I shut my truck off. I took it to a local shop this morning to see what was wrong but their scan tool wouldnt read anything on the brakes. We played around with a test light and came to the conclusion that the circuit board that sits on top of the pump is shorting out and telling the pump to run continuously. I called the not so trustworthy local dodge dealer and they told me that the motor was bad. I told them what we had found and they agreed but they are saying that the motor is going bad also and that I should replace it too. the circuit board is $370. 00 and I think the motor is around the same price. Please help :confused:
I've put only the module on if the pump is not too noisy (or have other issues). I work at a Ford dealer but we have the same Kelsey Hayes ABS set up, and have seen this a couple times. Have had no problems with either one after the repair.
HTH,
Wayne
If you end up having to buy the parts don't forget mopar4less. They saved me big bucks on an A/C compressor.
