ABS light
This is a common problem and it probably has nothing to do with the booster. My trucks have done this and required bleeding. There is a valve on the frame at the back that must be bled out as well. It is a very agravating chore.
You can disconnect the ABS controller and that will make the light go out. It is behind the glove box. The brake light will still work with the park function.
Do a search. The ABS is generally useless on these trucks and in some cases dangerous to your health.
This is not a recomendation, just my opinion.
James
