Hi Folks,I rebuilt the brakes in the truck in my sig. 600mi. ago. new everything from the hard lines to the wheels,and I thought everything was fine until 600mi. after and my abs and brake light have come on. I read lots of posts before doing the job and thought I had bled the brakes sufficiently but I suspect that because I have 4-wheel abs and the associated hcu's and such that something still had air in it causing the pressure differential switch to activate and set a code causing the light to come on. I have checked for codes w/a scan tool but I don't think I can see a code w/out a DRB II tool. I have tried rebleeding the lines and also disconecting the batteries . I am picking up a new hose trailer wednesday and need to figure this out asap. I don't think this is a speed sensor issue although it is possible. Does anyone have any input such as verifying diff. pressure switch position,etc. My Haynes manual says that on 97 and later trucks w/ abs this needs to be done at the dealership , but after paying $1700 for a clutch job recently(I wasn't home to do the job myself) I am reluctant to take it in. I will be working on it all day and checking this post for replies so if you have any ideas I am listening. Thanks
