2nd Gen Non-Engine/Transmission ABS light/Brake Light
Engine/Transmission (1998.5 - 2002) Trans shift kit????
Engine/Transmission (1998.5 - 2002) EZ Problem/ Question
Replaced my drivers side hub today and also new rotors and pads all the way around. On the test drive I noticed that my ABS light and parking brake light did not go off. Came back and restarted the truck and the same thing. Any ideas on what I missed? do you think I need to readjust the parking brake? No ideas on the ABS. Unplugged and replugged, still the same result.
Another member had the same symptom;s as you and I believe he changed a rotor also. I believe he had the wrong rotor as there is a sensor on 4wd vehicles that reads a tone ring on the front rotors/hub assembly. It will give you both lights if it is not reading. I would start looking at that rotor,sensor. The sensors ohm at around 600.
Dave
