My ABS light and Brake light are on constantly since this am. I have searched the forums and found alot of info to fix. My problem is, the ABS motor still runs after the truck is shut off. I had to pull the fuse, and both lights are still on. Only one guy had the same problem (ABS motor running in addition to lights), and the thread doesn't give a solution. I show no codes using the key on and off method. I realize the sensor in the differential is the most common cause, but would this have anything to do with the ABS motor running constantly?
2001 Quad 4x4, Loaded, Westach Guages, FASS
