The other day I shut off the truck and heard a humming sound under the hood, upon further inspection I found it to be the ABS motor was running. It would not shut off unless I pulled the fuse from the engine. I replaced front brake pads and rotors, the driver side pad and rotor was shot. Put the fuse back in and still have the same problem, the motor will not shut off, any ideas. Could it be the sensor on the rear differential, my ABS light was coming on before any of this happened?
