The Factory compressor is a Denso unit, and is relatively good quality.
If you replace the compressor, and you plan on keeping your truck, you should replace it with another Denso unit. In my opinion, the other brands are no where as good. GPD and Four Seasons are not as good as the Denso units.
If you replace the compressor, you need to replace the orifice line and the accumulator. The compressor comes with the expansion valve.
From Napa, the Denso compressor is about $300, the orifice is about $35, and the accumulator is about $30.
From Rock Auto, the Denso compressor is about $200 , the orifice is about $22, and the accumulator ranges from $13 to $20 (get the more expensive unit).
If you look at the P#s between NAPA and Rock Auto, you can match the same components (the P#s will somewhat line up).
If you can wait a few days, get them from Rock Auto. All the new lines and parts will come with the necessary o-rings/seals, so you do not need to buy new ones.
These systems use PAG 100 oil, ensure you put oil back into the system.
You might want to consider replacing the condenser as well. it is exposed to rocks, and all other types of road debris and is probably pretty beaten up by now. Get a Spectra unit, for about $74.
There is one more hard/soft line, which goes from the compressor up to the condenser and from the compressor to the evaporator (it is shaped like a Y and has foil insulation wrapped around it). It is around $53.
By replacing these parts, you will have replaced all the parts under the hood, leaving only the evaporator in the dash left. What the good part is about doing it like this, you do not have to fight with the fittings, with the exception of the two which go into the evaporator. Just take a die grinder and cut apart the old lines.
with the two that are left going into the evaporator, with the line cut-off at the accumulator, and the other line to the compressor cut, you can insert the extraction tool, and can now freely rotate the line, which will make pulling them apart 100% easier (still a PITA though).
Dumb question, but do you have the tools to take apart the fittings? They are the same as fuel line disconnect tools, Astro tools makes a good set of machined aluminum. I would not try the plastic ones, they will probably break. These fittings are a major PITA to get apart. They take a lot of patients, but will come apart. The website below is just for reference. This kit will work, but shop around. There are other kits out there, but this is the one I personally use. You will need 3 or 4 different size tools to get all the fittings, including the two largest ones in this kit for the lines to the evaporator.
http://www.thetoolwarehouse.net/p-27909-6-pc-ac-and-fuel-line-disconnect.aspx
If your compressor burned up due to lack of oil, you will want to flush the system. You can get flush kits online for not too much, check E-Bay. Technically, you should always flush the system, but if you are replacing everything under, and the compressor has not burned up, then you can get away with not flushing the system.
Ensure that you vacuum the system down for at least 30 min down to -30 in mg to ensure that any residual in the system is pulled out / evaporated. You should use a micron gauge (if you have one) and pull the system down to below 100 microns (depending on your vacuum, this will take about 30 min). Leave a vacuum on the system for at least 2 hours after you have pulled the system down (with the pump and gauges turned off) to see if there are any leaks.
Have you replaced the evaporator before on this truck?
If not, you might want to consider that as well (not fun, your dash will crack and is a pain). Do your heater core at the same time, and probably the blower motor as wel.
On a side note, R134a is getting expensive from the auto parts stores. If you buy a few of the little cans from the Auto parts store, you will be out $100.
You can buy a 30lb can for $86 from e-bay. Just as an FYI, you do not need a license to buy 134a.
http://www.ebay.com/itm/NEW-factory...Parts_Accessories&hash=item4aca22e961&vxp=mtr
If you have any AC questions, please let me know, I will try and help you out where I can. Overall, this job is not too difficult, it just takes a few special tools.
If you get everything from Rock Auto, you are looking at about $400 for the parts (with their 1927232316877708 discount code).
Freon and Oil will run you about $100 for a 30 lb keg of r134a and 2oz of PAG 100.
The Astro tool kit is about $35.
If you take this to a shop, you are probably looking at $1000 to $1200 for this work.
A few other special tools you will need:
Vacuum manifold gauge set, preferably with gauges that read R134a temps/pressures.
Vacuum pump which can pull 30 in mg.
Micron Gauge (optional, but good to know that the system is pulled down)
