So took a drive yesterday and WOW no AC in a truck in rush hr traffic sucks.
So today I hooked up my scanner and pulled the following info.
Truck says it is 84F outside
With AC off pressure is 135 PSI
With AC ON pressure Jumps to 268 PSI
Again this is what the truck is seeing VIA its sensors VS actually hooking up AC gauges on the low and High side. Pretty sure it only has the 1 sensor.
But I get ZERO temp change out of the vents.
Looking under the truck I see a line of stuff on the coolant hose to the radiator, "Assuming it is clutch material" the clutch on the AC does engage and it spins with the belt, no idea if the RPM is exact or not, and it is a bit noisy.
Past history AC Clutch replaced, broken line to dryer and new dryer installed with recharge. Sense then no issues, been a few years.
SO here are my thoughts, the AC clutch is dying as seen with the material on the coolant hose right exactly in lin. Pump appears to be functional seeing as the pressure is changing but I suspect the clutch isn't engaging enough to pump enough fluid to cool....
So new pump and or new clutch? Looking for ideas I'm no expert.
AC brands?
Thanks everyone.
This happens to be on a 06 3500
AC brands?
Thanks everyone.
