2nd Gen Non-Engine/Transmission ac water leak in cab
Engine/Transmission (1998.5 - 2002) need twins advice
2nd Gen Non-Engine/Transmission Fire!
38flathead
I"m having aproblem with condesate water leaking in my cab on the passanger side . when I lift up my floorboard it is saturated with water. Ihavechecked the drain an it appears to be draining help me please thanks. the truck is a1997 3500 4x4 standard
If the AC is causeing the problem put a piece of hose on the end of the too short drain pipe. Tie wrap it somewhere below so that it will stay put. If it has been raining it may be the 3rd brake light. If it leaks the water will run down beside the rear window to the floor and run to the front. The rear floor is elevated a little so the leak won't show up there. There are other things that can leak, but those two are the most likely.
i extended the drain tube on my 96 and that seems to have stopped it, it's a common problem on the volvos i work on every day and i figured it was the same thing happening, any tube that will slide on snug and hang down a little so gravity will take over and deal with the water
I put a 90* elbow in the end of the drain, waiting to see if that is all that it takes, but a piece of hose would work just as well, I was at the depot so I picked up the elbow for next to nothing. We shall see.
