I do the same. 5W-30 Syn in the xfer case.
JimP said:Type 4 synthetic fluid was not required for the 47RE untill 2001 model year.
RDrescher said:DTT does not reccomend +4 because of the friction modifiers that are in it. I believe this is for all 47re's. I personally use +4 & at 135,000 it shifts like new. We see -20 here & I feel better with synthetic fluid. I am going to change to Valvoline synthetic as I can get it for about $6. 00 a quart. I use the Cummins/Valvoline Extreme 5/40 & this is superb oil for the engine. Holds viscosity as well as 15/40 Rotella. When I buy a DTT trans. I will use the +3 as Bill says. Randy
DavidWhite said:Let me throw everyone for a loop. I use John Deere Hy-guard trans-hyd fluid in mine.
DavidWhite said:Let me throw everyone for a loop. I use John Deere Hy-guard trans-hyd fluid in mine. I tried +3, +4, dex/mercon, with lube guard & without. ATF does not lubricate worth a crap! The Trans-hyd fluid lubricates better, cools better, and lasts longer. Oh yeah, its VERY inexpensive! .
BTowler said:Actually, DC changed the requirement for all vehicles except some minivans to atf+4, including previous models in order to maintain warranty. A nice little money making ploy for them since they were the only source and refused to license the formulation to anyone else.
DavidWhite said:I've been running the Hy-guard for about 6-mos. now, and like it. It really keeps the temp down.
SAndreasen said:my transmission takes almost seven gallons but its worth it to use the rite oil i think
