Access Plug
Killer dowel pin in 24 valves???????????????
Alum rims on 93 dually HELP NEEDED
HEMI®Dart
Preston,
Are you talking about the big hex plug on the governor housing, under the safety wire that you can access the Gov springs thru? (see below)
I couldn't find any p/n's or sizes. Its like a big flanged plug with a hex fitting in the center. Probably will need to get it at a Bosch dealer.
The plug came out? Unbeliveable.
[This message has been edited by HEMI®Dart (edited 05-06-2001). ]
Hemi:
The plug I'm refering to is on page 14-74 in the 96 manual, fig 9. To the left and below the plug you are thinking about. . The bracket or plate the plug is mounted on is held on by two bolts, staancing vertical.
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system, AutoMeter Pyro & boost, Primeloc
Joe is right. I see it now. It almost looks like an acorn nut. It is the access port for the pump timing tooth, like you guys said.
For a '95 P-7100 I have Bosch part #'s
3912888 Plug, Timing
3912889 Washer, Sealing
11 ft lbs torque.
OK men, I have another question:
I noticed I was losing a good bit of oil and I thought it was the power steering pump. Well I cleaned it up and went down the hwy. to see if I could tell where it was comming from. Quit a bit of oil. I found the cause of the leak and now I need your help.
The "injector pump access plug" came off and the oil for the pump is comming out there. A lot.
Does anyone know what size hole that is and what will fit it? P7100 pump but it's not the 913. 887 I think or something like that.
Can't drive the truck even to get the part.
Any ideas??????????????????
Thanks... ..... Preston
