Actron scan tool
Cummins Quick Check
Power Edge, or EZ? need answers fast
I did a lot of research before I bought a scanner and settled on an AutoXray. They sell one basic unit that can be configured the way you want it (OBD-I, OBD-II, both, or with various manufacturer enhanced OBD-II, etc. ) It can also be upgraded by programming a factory code that unlocks the desired mode should you need it later or by downloading a program or update from their website (with optional software and cable). I paid about 350. 00 for the full blown, all inclusive model from a local parts store.
I have a 96 12V and can read/reset codes and get limited info from the PCM. I have tried it on a 24V and was able to access more info. The company is working on a Chrysler Enhanced upgrade that may allow more PCM info to be read. Above all, I have been impressed with the top-notch service from this company.
Check out their site http://www.autoxray.com. There are a couple of PDF downloads of good comparison reports that include the Actron unit as well as the usual high-dollar scanners.
Bob
Bought one... . returned it the next day... ...
It simply doesn't work on our Cummins Rams... ...
I even pulled my MAP sensor to set a check engine light... . light came on... . scantool found NO FAULTS!!!!!
http://www.ghg.net/dharrison/obdscan.html
This tool seems to work better.....
The Palm version is buggy. . but the PC version works like a charm.
Larry
