Actually this is about the rearend......
power steering fluid
Where to buy Racor 690 filter kit?
I realize it would be best to replace the factory cover with a better product. But, is there enough clearence to tap and install a temp probe in the stock cover?
Todd
Yes there is but it won't drain all the oil out especially the sludge on the bottom, need to wipe that out with a rag.
The way I've done it on other applications is to cut a pipe coupling in half and weld it to the bottom of the cover, drill the hole after welding.
The mag-hytec diff cover has a place for a temp probe. I like mine because of the dipstick with a magnetic tip and a drain plug which is magnetic as well.
It doubles the volume of the oil in the diff so the oil is cooler.....
http://www.mag-hytec.com/
