Has anyone had a weak actuator? Reason why I am asking is for the last two year if I put the fan on low speed and change from heat to defrost it works fine but if the fan is on high it won't switch. Then you have to put the fan on low and play with the control a couple of times then it changes. Also, if I put it on 50 / 50 floor defrost and turn the fan on high it will close the door and all come out at the floor. I know there is a history of broken doors but I would think it would of stop working all together by this time or get stuck in ether position not just floor.
Any and all help is appreciated.
