High Voltage
OK, 13, 104k Miles, Have had absolutely no problems. Went in for a pinion seal leak. When on the rack they frond coolant leaking from behind the Actuator ( Been leaking for some time but it was just a drip and was not ready to open up a can of worms) But IT was now leaking a bit more so why not get it fixed, remember there has been no problems. Get truck back and everthing as gone to SH**!!. EB would come on and not go off Dead throttle, and this is with the EB switch OFF. Turn it on got worse!
Start off EB would stay on then about half throttle it would go off then we got a race truck....
Only code that has come up is P0471 Exhaust manifold pressure sensor.....
Pulled Battery's checked all wiring all good. Seems to get a little better when at temp but the EB still comes on when not turned on witch will make the truck buck until it goes off.....
Hoping it's not the Actuator but it is getting close to that time.
EB is used all the time not just when towing...
