Add-on cab clearance lights?
New Member
Just hit 30K- wanted to ask an oil question-
Has any "Doityourselfer" out there added aftermarket or OEM cab clearance lights to their 2500?
Was the wiring harness allready in the roof?
I can't see myself drilling holes in my roof yet, but I am thinking about it... Thanks, MH
Erik F.
2001. 5, Silver, Quadcab, Longbed, SLT, 24V, Auto, 3. 54 LSD, 2x4, Tow and camper packages,
(Add ons) Pioneer, Husky Liners, Tint, Diamond Plate Tool Box, and Rail Guards, OEM Bedlinner, OEM 4x4 Mud Flaps, K&N, Geno's Breather Vent Catch Can.
(Wish list) 4" Exhaust, Low stall converter, Built transmission, Banks Power Pak.
the easyest way to add clearance lights may be to just add a visor with the lights in it. the lights hook to your light switch.
JRG
Don't have answer to your guestion but do a search. A little while ago several people added clearance lights and said it was a piece of cake. Only problem was building nerve to drill the holes!! #ad
2001 RAM 3500 dually Quad Cab SLT, 4. 10 limited slip, HO 245 hp, 6-speed, dark garnet pearl coat, interior agate, All options except heated leather, added DeeZee brite diamond tool box, Linex spray-in bed liner, Lund hood deflector 3 piece smoke color, DeeZee brite diamond cab/bed running boards and TurboSaver (from Gino's) also Reese 5th wheel 15k hitch. No plans to bomb. This is my retirment vehicle currently pulling 21' 5er want to buy 30 to 35 for retirment.
Great info Guys, thats what I needed, Thanks... MH
Erik F.
P/N 82205120
You might wish to check the style of light in this kit. When I purchased this part number it came with Peterson 120 series lights. I believe these are the "old" style lights.
You can find them here:
http://www.pmlights.com/
Thomas . . you're correct . . that is the old style.
www.mopar4less.com There is a 1-800 number posted. Tell them you want the new "low profile" light kit for the 2000.
There are several good posts on this topic . . even recent ones. Poke around . . I'm sure the new style kit number is posted.
I installed mine . . less that 2 hours . . instructions are complete . . drilling template is a piece of cake to setup. The hardest part was positioning my stocky self so I could drill those friggin center holes.
Good luck
Michael
00 Driftwood 2500 ST QC ISB LB 5spd 3:54 LSD Tow & Camper Groups . . SunnyBrook 33FKS Travel Trailer
my photos
When you pull the headliner down, you will see a reinforcement rib running across the roof. It will have 5 1" holes in it and that is where the lights go. You won't need a template, just get a 1" hole saw, and drill straight up through the holes in the rib.
It is not a 1" hole for the "old style" light kit so, measure twice, cut once... check the size of the hole before you drill... blah blah blah
243
99 QC 2500 ST 4X4 SB 24V/5speed 3. 54/LSD Driftwood/Agate
Walker 21468, VDO, Bridgestone 285/75/16 MT's, RS9000's, Hella 500's
http://www.0hassleisp.com/dwilk/243'sRamPage.html
-- email address removed --
Hay Guys:
I installed the Mopar kit on my truck. Dropping the head liner, drilling the roof, instlling the lights, running the wiring were all cake. About two hours with a couple of beer breaks worked in. #ad
Then, I spent another two hours trying to stick the little wire to acitvate the lights in the back of the fuse block. Haven't seen anyone else posting having problem with this though.
They shore due look good!
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch,Mag-Hytec dif cover.
Wire Dawg,
Where did you get the kit?
My dad just bought a 2001 Dodge without and the dealer told him to add them on would be $400. 00 (their cost).
Mine were added on. No problems. Less than 60. 00 from a dodge dealer. Looks good.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
