I'm on a mission to make my front wheel bearings last a long time so I added grease zerks to them while I was in there changing axle seals and wheel joints. I have put about 233k on them since I installed this '96 axle when I got the truck in '01. If the bearings are original to the axle they now have about 360k on them and they are still tight and smooth! I did add grease to them some time back by pulling the seals and packing a little grease in and then installing another set of seals from a set of bearings I changed on another truck (I pressed the bearings apart so I could get the seals out without damage).
I drilled dead center on the bearings with a small magnetized bit and then used a magnetized pick to check for any shavings but none came out. I then used a larger bit to drill the end for zerk threads. I installed a 90 deg. zerk pointed at the steering knuckle where I drilled a 5/8" hole through the knuckle, brake disk shield plate and spacer. I can now grease the bearings anytime I want without disassembling anything. It will probably go a long time before any grease is needed depending on how well the outer seal holds up (that's where mine seem to leak some grease out). I didn't pack them clear full and blow the seals out.
I don't have good luck with the greasable u-joints even when I keep up on them. They also throw grease all over the body so I went with the Spicer 5-806X sealed joints this time. My cousin's truck is still on the OE joints up front with 307k so I'm a believer in the high end sealed units.
