Any tips or tricks to add and egt port to a stock factory manifold without pulling turbo or manifold out?
Common rail manifold is a little different as the turbo is farther back than that diagram, I did the same with a vacuum and grease method, put the probe on the top side of the manifold right after # 3 dumps in, then you get temps from all 3, as it is a little weird how 3 and 4 dump into the turbo with the turbo mounted directly under #4 rather than in the center like the gen 2 trucks... JM2C.
I’ve seen some photos on people putting the probe in the elbow that comes off the turbine housing. Bad spot?
Because of the pressure drop across the turbine drive wheel, you will see about 100°F to 400°F temperature drop (depending on engine load) from the temperature in the exhaust manifold before the drive wheel. That's why most people place the temperature probe in the exhaust manifold.
- John
I liked pre-turbo for working the motor hard and post-turbo for cooldown purposes.
Truck is an 04.5. Does that make a difference. I’ve seen some photos on people putting the probe in the elbow that comes off the turbine housing. Bad spot?
That makes perfect sense and sounds like a great idea. Did you put in two separate gauges, or did you just multiplex the two sensors to a single gauge?
