2nd Gen Non-Engine/Transmission Adding Keyless remote
2nd Gen Non-Engine/Transmission CTM? - Where is it located?
My 99 did not come with the factory alarm and keyless entry option. One of the first mods I did was buy the factory alarm kit from a Mopar dealer and installed it. All the wiring was pre-made and connects just as if it were installed at the factory - works great, but took quite a while to install. Not sure if they are available anymore, but I would check into it before buying an aftermarket system.
I have seen them advertised for the diesel 5 sp, but I cannot remember exactly where. I am guessing they must have a sensor for the park brake. Given that I live in a cold climate and have had problems with brakes freezing, I won't set my park brake overnight. I would have to go out and set it anyway, so I figure I might as well just start it while I'm out there.
i repalaced my factory keeyless with a $110 one from circut city. it came with a remote start and keyless entry. it has a feature for a turbo cool down. if you activate the parking brake (get the light on) and then take the key out you can set the amount of minutes you want it to run to cool off. i like it. i reused some of the relays and such for the factory lock unlock. it took 5 hours but the power went out that night too... . it rea;;y wasnt that bad. and the remot really does work from about 500-700 feet away.
Wow, that is wonderful news for me! I had assumed that the only solution was to get the parts from a junkyard.
Which one did you get, I see they have several.
Thanks for that tip!!
i put it in myself. took awhile but i got it. they have the electrical diagram on their website. problem is i cant remember what it was my key fob only has a 1-800 number. its 1-800-421-3209 i tried calling but they are closed. i will try to find the manual
