actually I lost a lot of bottom end when I switched to the SO pump, but now that I have the 275's and the EZ, I gained it back and have more top end to boot. I made the swap though cause my old VP was going out, and I have plans for over 500hp someday.
Darkhorse, your exactly right, its got bigger plungers than a HO, so it pushes more fuel, but it does so at a lower pressure, so i've been told anyways. I just wasn't sure if the module on the pump itself controlled timing or if the engine ecu did.
So in other words, the module on the inj. pump is basically just a "middle man", right? It makes the pump do what the engine ecu tells it too.
That's because even though the plungers are larger in the SO pump, the cam ring isn't as aggressive. The hot ticket is to add a SO rotor head and plungers to a HO pump with HO cam ring. About 40rwhp.
