While browsing through my Summit catalog today I found a remote mount filtration unit marketed for transmissions. The unit uses an equilevent filter to the Fram PH8A.
It is nothing fancy, a remote mount filter head, some 3/8" line and some fittings. The price is ~$29.
Do you think there is anything wrong with this unit for adding additional filtration? I'd just like to use a 2nd full flow filter for some extra filtering capacity at an inexpensive cost/maintence (yes I'm debating a Bypass unit as well and I understand all the added benefit of the Bypass).
The filter port on the top of the oil filter housing, is it oil that has been already filtered or is it unfiltered oil?
Thanks for the information,
Ryan
Edit: How does the Amsoil Bypass work? If the filter is completely clogged, does oil still continue to flow, hence the name bypass? If so this could be a problem with the above filter, no bypass valve.
[This message has been edited by Cooker (edited 03-28-2001). ]
Ryan
