Adjustable Master Cylinders
Oil Level Gauge: is it possible?
Boost from bottom turbo in twins.
Between Liberator performance and ourselves, we have designed an Adjustable Master Cylinder. We are now in the process of making them in quantities. I do not have the pricing as of yet but I wanted to get an idea of the desire for this product.
Purpose for it: For those troublesome situations where you need a little extra throw out of your hydraulics. You will also be able to set the clutch engagement to your desired position.
I am not taking orders right now but would like to here from you on this forum if interested. I will also try to answer any questions you may have.
Peter
HMMmmm - I didn't remove the throwout rod from the clutch slave cylinder when I did my clutch replacement, so don't even know if it's permanently attached to the internal piston or not - but if it is NOT attached, sure seems like it would be quite easy to fabricate an adjustable push rod to accomplish what is being discussed here - should be easily accomplished with common hardware parts for about five bucks...
