JF, Welcome to thee best resource of CTD info. w/a touch of B. S. added for flavor!
Valve adjustment is very easy, The timing pin may be a bit hard to push, but you only need to do it once providing you mark TDC on the harmonic balancer.
See the "drawing" below:
1st. TDC:
Cyl# 1 2 3 4 5 6
Valve I E I E I E
Rotate 1 revolution and adjust remaining valves:
2nd TDC:
Cyl# 1 2 3 4 5 6
Valve E I E I E
# 6 is the only pain, other than that its no different than a gas engine.
1st TDC will get I&E on #1- I on #2- E on#3- I on #4- E on #5
2nd TDC will get E on #2- I on #3- E on # 4- I on #5- I&E on #6
Hope this helps.
Do this COLD, Also, in my opinion, get rid of that Haynes book and go for the factory service manual. Good luck!
Mike
The "drawing" looked better before posting... the site eliminated the spaces!
