I installed a switch in under the dash to instantly advance the timeing when I want.
I tapped into the line side of the large resister mounted on the side of the intake manifold above and behind the fuel filter.
The resister is mounted inside a rectangular steel bracket.
The black wire out the back of the resister is the one you want to tap into.
The ksb solinoid is only 9 volts and I dont know what would happen if you hit it with 12 volts, probibly burn it up. thats why you need to knock the voltage down with the resister.
this mod has the same effect as when the thermo switch in the intake manifold closes, it sends power to the resister and the timing is advanced when the truck is cold!
I like having the option to advance the timeing whenever I want , after all the 24valve get to with thier boxes
Happy bombing
Eric
