J. BURCHFIELD said:Tear a page out of the big trucking companies book and use synthetic and install a bypass filter. The bypass filter should be a 2 micron filter. All of the oil in your engine will pass through the bypass filter in about an hour or less of highway driving. Once you have converted over to synthetic oil change both filters at regular intervals and leave the oil in the engine. Be sure to fill the canisters with oil as you install the new filters so as not to starve the turbo of oil on initial start up. Expect to get one million miles. A few years ago a friends son had 960K on his cummins and had not changed oil or laid a wrench on his engine. The oil will get black but it is not due to dirt, it is a just what happens and is harmless. When oil (synthetic) is passed through a 2 micron filter the engine does not wear, it just polishes. This is not a recommendation, just a suggestion. I know how opposed to synthetic some people are. Synthetic is man made from chemicals and does not break down as does oil from the ground. It is your truck do whatever makes sense to you and what you feel comfortable with. I have a Nissan with a high revving 4 banger gasser in it that has 207K on it. I started with synthetic at 25K. It runs good. Because I would loose all the oil when I changed filters I changed oil every 25K. The oil I use is from a slight drip not from burning it, no smoke. In your area I would use 5 w 40. It is what I might change to if necessary when I move back to Ohio from Florida. -- email address removed --
I'm not sure what big trucking companies you are speaking of, but industry standard is to use a conventional lube such as Delo, and standard filtration. Most companies will establish oil change interval based on the manufacturers recommendation. Doing anything else may void the engine warrantee. Since most major companies buy new tractors it makes economic sense to comply with manufacturer service intervals.
