J. R.
Can I ask why you are asking for electric fuel pump info?
Is this for your truck?
I ran into this problem over a year ago. I finally did enough testing to show that my stock pump wouldn't move enough fuel volume to maintain pressure under WOT.
So far, I'm the only person to have ever had that problem though, that's why I asked. With only 1-3 psi of fuel pressure (my case) feeding your pump, the barrels don't have time to fill properly. Installing an injector pump camshaft ground for more fill time doesn't help if you don't have some pressure pushing the fuel in.
I tried enlarging all the banjo fittings. I tried a high flow fuel filter. I played with the overflow valves and even tried a new stock pump. In the end, there just wasn't enough volume to keep up.
I didn't want to add a pusher pump because the fuel heater leaks under pressure. I didn't want to give up the reliability of my stock mechanical pump and I also didn't want to give up my fuel heater for winter temperatures.
I decided to add an auxillary fuel pump with its own suction directly from the tank and feed it in at the banjo fitting on the P7100.
The aeromotive pump quickly caught my eyes, but I was cheap and passed because of price. I used a holley electric pump, but found one used in fuel injected cars because it is designed to run at 50 psi all day. Most high flow electric pumps aren't designed for the pressures we need.
Under normal conditions (pump off), I still have all the benefits of the stock system (reliability, heater, etc. ), but once I turn the pump on, the pressure never drops below 40 psi.
Problem solved.
To answer your question though, I believe Chris Sutton has been running the aeromotive pump for quite some time on his truck. But being a 24 valver, he has different pressure requirements than your truck does.
If my current pump ever has problems, I'll step up to the aeromotive.
-Chris
