Engine/Transmission (1994 - 1998) afc boost line
The boost line from the intake to the afc on my 96 has sprung a leak. Is there anywhere to find this line or is there a better aftermarket fix for this issue. Thanks in advance for any help.
I'. ve never replaced mine but if you cant find it I'm sure a copper line and fittings would be available at a plumbing supply
The easiest way to fix it would be to go to a parts house like NAPA or Carquest and buy two 1/8” male pipe fittings to 1/8” or 3/16” flare and a short piece of pre-flared brake line. The fitting on the head will be 90 degree, and a straight one for the AFC. You could also use a piece of plastic hose with compression sleeves (“olives”) and fittings. Cummins probably can order the OEM part but I suspect it would take longer and cost more.
