I installed the softer of the 2 springs that comes in the spring kit. I now have some hesitation before boost starts building that I did not have before, and not quite as much smoke . I thought before I swap to the stiffest spring I would get some input from some of you guys. I have the #5 plate in the stock position. With the stock spring and the screw that is located on the backside of the housing backed off a couple of turns, the truck really run good, which I will go back to if the stiff spring does not help.
