Scott,
Depends on when it was made. The later models will usuall y fit either way.
On the older units you just simply have to cut about 1" of intake wall off of the afe unit then re-attach the rubber sealing gasket.
But if the hood closes on the intake without issue then its ok. If it closes but you can see interference then you will need to trim.
