for another county heard from-
I have ISSPRO EGT and Boost (black face) installed in dash top pod.
Have had no trouble at all with them. (mechanical boost)
I have Auto Meter phantom mounted windshield pod-
engine oil, trans temp, rear end temp.
Also have Auto meter electric (stepper motor, expen$ive) fuel pressure
gauge mounted windshield pod. No problems with any of them, 1 gripe-
The oil temp and trans temp and rear end temp gauges are identical guts,
just different printing on the gauge faces. (one says oil temp, other 2
are same part number, say "trans temp". ) On the 2 trans temp gauges,
looks like the gauge needle was pressed onto the pin reading a different
temperature. I didn't realize this before I installed them, but in the "off"
condition, as well as when the truck is first started after sitting for days,
the trans temp gauge always reads about 15 deg higher than the other 2
temp gauges, when I know all the fluids are same exact temp.
I suspect the guage needle was pressed onto the pin a few degrees off-
not earth shattering, but poor quality and annoying. I just figure my trans
temp is about 10 deg higher than the gauge reads.
If I had realized it before the installation was complete, I probably would
have complained & sought return / exhange. But now the gauges are up
there on the windshield pod, and everything went so smooth with the install,
I don't want to tear it all down just to fix a 10-15 degree difference in
one of the pointers. When trivial problems like this are worth typing all
this on a forum... . life is good !
