AH64ID
Well, Guess its gonna be off with the PAC Brakes (up for sale W/2k miles on em), replace with 5 leaf mini pack and the Carli Torsion sway bar kit on the front. . I have contacted and waiting on a reply from Thuren and Kore to see if a Softer VR coil W/out the lift would be possible. .
I could care less about the increase in lift from VR coils, just want a softer ride. . I Wonder if a 3" VR Coil can be trimmed off at the top to eliminate some of the height? If ya don't run off road real hard and put some softer Carli bump stops on ya should be ok I would think. .
Another option maybe to:
If adding a leveling kit, the "Thuren" (http://thurenfabrication.com/perfshackles.htm) performance shackles could be added to the rear and installed with the additional 1. 75" of lift on the rear which would retain some of the OEM rake and maybe solving the rear sage when towing??
Will report back if there is a solution!
Are you not going to have any sort of rear airbags installed at all?
The mini pack will support OEM loads, but when I called and asked they said it would ride lower than it did stock.
Is your main concern the ride or towing your 5er?
