air brakes adapter?
HX40V-----Variable geometry??
Roadmaster Suspension: My Verdict
Where are the TDR forum archives?
Originally posted by McDowra
Does anyone make a adapter so we can pull atrailer with airbrakes?
I posted a question on this subject more than 18 months ago and was going to quote you an in-line TDR weblink pointing directly to the thread(s), but for some reason, I cannot locate the TDR archives... . anywhere?
I hope I'm looking in the right place. . ? Anyway, hopefully someone will shed some light on the missing archives and I can then point you in a direction, where at least you'll get a considered perspective on the viability.
Is your proposed set-up (going to be) configured for suck or blow?
What is your primary air compresor supply and tank?
Where are they located?
BTW, if you're thinking of running a Cummins air compressor off the rer of the CTD in your Dodge, forget it... . There ain't enough room back there and the HD Dodge rear engine support conveniently sits right in the same place where a Cummins air compressor would go... Nice touch DC :rolleyes:
Like I said, if I could only find the TDR archives, I could cut you to the chase..... anyone feel free to chime in here.....
