Air Conditioner Clutch
Injector Upgrades
AGR Steering Box
My Air conditoner clutch decided to go south sometime over the winter. Today was the first time i checked it since about September(it actually got to 70 deg. today!!) anyhow i need to get a clutch, any ideas where to go, i tried a chain auto parts store. but they cant get them.
Nick
95 3/4 ton, 4x4, Auto, 235 plate, K&N, straight through exhaust, wastgate mods, more to come, 108,000mi and still going strong
Bad news, the clutch isn't available separately, you have to buy the whole pump. They are available from sources other than DC and also rebuilt for a fraction of the price
Do a search on the topic. I posted this stuff before but I can't remember exactly what I posted.
Check out
http://www.aircondition.com
lots of good info on automotive air conditioning. There is a vendor in AZ that is very knowledgeable and helpful
http://www.airsource.com
I think a couple of guys replaced their clutches last year using that source.
Dave
2001. 5 2500 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and Autometer transmission Temp(sensor in the line) in an Autometer Dash Pod, SW Fuel Pressure Gauge, Westin CPS Platinum Step Bars - Black on Stainless
[This message has been edited by Dave D (edited 04-07-2001). ]
I just got my truck back (Friday) from my Local Dealer (Paul Young), when I got my truck Back, The air condition wouldn't turn on. Compressor won't Start, It seems like the clutch went out. Sems odd that it was working perfectly when I took it in.
Mechanic said it was that way when he got it.
Does anybody have any Ideas why My Compressor doesn't run?
I have checked all the fuses ( A/C clutch relay, and A/C Clutch Fuse).
When I reached down to turn the compressor over, it turns just like it should, Just a Little hard to turn, (Doesn't free-wheel), but it still turns with one finger.
I can't figure out why it won't turn. I wanted to ask everybody here FIRST, BEFORE I took it to an A/C Shop.
Thanks.
Regards,
MerrickNJr
1998. 5 Dodge 3500, 2wd
5-Speed, Light Driftwood
Replaced the Resonator and Muffler with 6ft of 3" Aluminized pipe.
3. 55 rear-end
A. R. E. Camper
Michelin 245/75/16's
101, check to see if you are getting voltage to the clutch when the unit is on. If not, bypass the low pressure switch, if it runs you are either low on 134 or the switch is bad. Ths low oressure switch is the one back near the firewall.
What did you have the truck in service for? Makes me wonder how the "mechanic" knew it was that way before. And if it was was why wasn't the issue mentioned at the time you picked up your truck or a phone call stating "hey did you know your AC doesn't work?" etc, etc.
Check with either a meter or a test light, to see if the clutch is getting power. Would be my first move.
I haven't had to spend any time under my hood, so I couldn't even tell ya the location of the compressor without looking, let alone the wiring connections.
(Knocking on head) so far been a great truck, haven't had to open er up other to tighten the boost clamps.
99' Qcab, 4x4, auto, chrome nerf bars, VA, Boost elbow, DiProcal Pillar mount gauges, 16X8 Eagle wheels, Dunlop 285/75 AT's
Nick
I had the same problem a couple of months ago. Got this part # 4746789 on this site. Took it to my Dodge dealer & ask them to put it into their computer it came up compressor cultch. IT cost$244 plus tax. hope this helps
illflem: I was told they were not available separetely also but part #4746789 worked for my 95. I think it doesn't come up in their computers,Ron
Found one at NAPA they had to order it but it was only 78 bucks. dont know the p/n but it was a stocked part at the warehouse.
Nick
Thanks A bunch guys, Really appreciate it.
One more thing I noticed about the truck since I got it back. . The overhead counsol temperature and compass doesn't work.
(Apperantly I'm not the brightest Kid on the block)
Took it to an A/C shop today anyway, Diagnosis was free #ad
Technicians found that the relay circuit wasn't recieving any power to turn the Clutch on. He Jumped the relay, and the clutvh worked perfectly.
So after abou 1. 5Hrs later Another technician finally concluded that there was a bad Ground SOMEWHERE, He just couldn't find it.
The tech said to bring it in Monday. (Not sure if I will. . )
<HR><HR>
I know how I can fix this problem with a $2 switch and some wire, but,!
Will it Hurt the compressor to run ALL The time the A/C Blower is On ?
3. 55 rear-end
A. R. E. Camper
Did he test the relay or is there no signal at all going to the relay? I've had two of those relays get weird on me - working sometimes, then not working. I used a known good one (horn) to test it. I also experienced the "bad ground SOMEWHERE" problem, which turned out to be a bad PCM. It took a lot of troubleshooting to find that one. I hope that's not your problem.
Bob
No Power going to the relay.
Relay works Fine. ( Checked it by moving it around to other relay slots. )
I took my truck in to have the Lift Pump Replaced.
okay, Update,
Took my Truck in Monday to have the dealer look at the PCM.
Called Tuesday and the Service advisor told me the machanic couldn't find anything wrong with A/C. (DUH!! I allready spent 2hrs doing that)
Waiting for them to cough up the PCM Module.
MerrickNJr
