Air-dams and Ground Effects
Decal
24 valve Holset turbo failures...READ.
Hello,
I'm a new member to TDR #ad
I am looking for a air-dam and some ground effects for my truck, There is not much out there. Can any one help me out?
Thank you
Jeff
Jeff Allan
31D 81199
2000, 3500,4x4, 355 gears Laramie SLT, BD valve Body, BD Torgue Convertor, BD pressureLoc,#14cm wastgate turbo housing, powermax 3 adjustable, stage 3 injectors, custom dual 3" exhaust with dual 4" barrel tubes behind rear tires. Trailmaster SSV shocks, ISSPRO Turbo boost, EGT gauges in piler, K&N air filter, bushwacker fender flares, black nerf bars, hellwig spring helpers, Let the BOMBing begin
Doug Hofeldt was working on a air dam that would have an air intake setup but I think you could get one w/o and just a fiberglass dam with provisions for lights. You can see a couple of pics of one prototype that's on his truck at: http://www.xmission.com/~rotohead/doug_hofeldt.htm
You can email him- hofedoug@mail. ida.net
or call - (208)232-2469
I don't know how far along he is on this project, haven't talked to him in awhile, but the prototypes looked promising.
-Chuck Krause
'98. 5 2500 QC ISB 4x4 SLT, Auto w/Transgo shiftkit, JRE 4" exhaust w/5"Tip, DD II's w/Module&Elbow, VA box, Rancho 9000's w/in cab adjust, Mag-Hytec trans&diff covers, Jacobs E-Brake w/BD autoloc, trans temp, boost & EGT gauges, 2Low Kit, Brite Box, Steel Horse Billet Grilles, AirBullDog hood induction system
